Stabil
Jim S.
White Bear Lake, Mn.
Little early to be talking about this but, I always wondered what Stabil does to gas. It must change the molecules somehow? I usually mix 91 non-oxy and 110 race gas 50/50. At times the math is off so only about 30% race gas gets in. I wonder if I really need to put Stabil in the car when it goes into "dry dock" for 5 months? I would rather not. :huh:
abodybill
Senior Citizen Member
MI. Farm
I been told that race gas will stay good for acouple years if kept out of sunlight.
The problem with mixing is the garbage they sell us now called gas as I know it doesn't last long to it's rated octane.
I to mix mine for the Dart and have not added anything to it while in storage and have not any problems when it comes out.
So as long as no problems I will not add anything to it when in goes into storage and as you know our storage comes up quick.
coyotekiller
Ridge NY
I use Stabil in everything I have car,boat, and even my lawn equip. and I never had a problem. :cents:
My friend Randy uses it in his fleet after having to clean a fuel system on a couple of cars. No problem since
I've never added anything for the wintertime. I'm usually low on gas, and just add fresh as needed for the winter run ups.
I never use it either. Fresh gas on start up is all you need. With today's gas, it is totally evaporated out of the carb. in just a couple days.
Same here. The only thing when I start up in the spring is the extra cranking getting the gas up to the carbs again!
roadrunnerh
Pittsburgh, PA
Same here, I don't use anything over the winter. I usually store the cars with at least a half a tank.
