I think your to the point that you take a volt meter or test light and see how far your 12v is going. Good way to find a bad ground also when you use a different ground source when testing.
Basketcase said:check the dimmer switch(on the floor) and the plug for it. I've had those cause the headlights go out. don't know if the dimmer affects the other lights, usually loosing the headlights while going down the road gets my full attetion![]()
69hemibeep said:I think your to the point that you take a volt meter or test light and see how far your 12v is going. Good way to find a bad ground also when you use a different ground source when testing.
I think we should sit down to a cold :cheers: and talk about ohm's law JimJim S. said:69hemibeep said:I think your to the point that you take a volt meter or test light and see how far your 12v is going. Good way to find a bad ground also when you use a different ground source when testing.
Another way to accomplish the same thing would be to temporarily disconnect the battery and use a multi-meter to check for continuity. You will need a 6 foot piece of wire or 5 or 6 alligator clip leads. Turn the headlight switch on, then hook the wire or clip leads to the fuse for the tail lights. I think it is the 4th from the left. Then hook that connection to the multi-meter (common or neg. side). Take the positive lead from the meter and touch to the same point on the fuse box just to make sure it shows a short (continuity). Now take that positive lead and head back to the tail lights. Remove a bulb and see if you have continuity to one of the center contacts inside the socket. If you do, then its a bad ground. If not, then you have to start tracing it. I just figured this would be a quick way to prove a good or bad ground........
dobie said:I'll definitely print this out and take it to the garage with me. I plan on getting back under her tomorrow. Thanks so much!
Basketcase said:
