three speed wiper swaps from two speed.
Ok so I had a two-speed wiper motor and switch. Putting the fresh air grabber on and had to change the wiper motor and switch. Is there anything special about the wiring to the new three speed motor switch I should know. Tried it yesterday and the wipers move some but not strong. The plug went on the switch, and the brown wire went to the outside prong for the washer switch. I got the motor and switch and the switch was used. So now have a new switch coming hope that is what the problem is. Any other info appreciated. Thanks.
Hey Russ. I had looked into replacing my two speed wiper with a 3 speed. The guy I was going to buy it from told me that the main under dash harness that connects to the switch may need a jumper wire added for high speed. He was going to help me identify it if I bought his wiper motor. I haven't pulled the trigger on it yet, so I don't have that information. I hope that helps some.
Don’t laugh, but I did the opposite… wired my “original” 3-speed wiper motor (in perfect condition) to work as a 2-speed. Did a few electrical changes so that both the slow and mid speed an operate a bit faster. The original fast speed was way too fast and the slow speed way to slow. Now they operate just right. I have an extra (still in the original vintage wrapper) 3- speed motor that will eventually accompany the car when I sell it. It would take all of an hour to swap the motor back to a 3-speed… which I will do when it comes time to part with the car
Thanks guys. I will keep this in mind. Just figured someone had done this swap at some point and knew what the bottom spade went to on the switch. Will keep at it till I get it fiqured out. LOL. It is a bit rough working under the dash getting older does not help. Be safe out there and keep those runners running. LOL.
Thanks for the info. I have the wiring diagram for the car also. I am missing one wire spade, and it looks like the brown with white tracer loop between two of the spades on the switch.
But will look into the wiring harness and see if one is there or not.
Very easy to convert a three-speed to a two speed and change the actual speed with the low speed between the low and medium and the high between the medium and high… way better than the high and low on both the three speeds and two speeds… does; however, require some basic electrical knowledge!! I set mine up so that I can now toggle between the original three speed and the custom two speed. Toggle is hidden under the dash (out of sight)!!
i also believe you need a different plastic cam on the end of the link coming off the end of the wiper motor for the piers to move and park correctly
