Tire Pressure Sticker
Here is mine, drivers door jam. Keep in mind it came with 15" tires so the info is different
Ranger
Woodstock ll
Thanks Beep, now I know WHERE it goes, just not sure which one is correct.
A12
Here are two original '69 Road Runner tire pressure decals.
The blue is from a 383 A/C car and it is NOT 30 psi front,! Maybe that's for a 440 engine with A/C but not sure if a 440 is that much heavier than a 383 with A/C??
This is off of my '69 Road Runner non-A/C and I would think it to be correct for a 383 Road Runner WITHOUT A/C.........BUT and that's a BIG BUTT :tennis: because my car, although it still has E63/383 engine on the original fender tag is an A12 Lift-Off-Hood Road Runner :tennis:
IMO 28 psi - Front and 24 psi - Rear is the correct tire label for a non-A/C 383 '69 Road Runner with F-70 14 tires.
A12
I'm having a heck of a time attaching the files/images?
A12
IMO you're looking for the tire decal with label code "77" in the lower right of the label which is the one in your first eBay listing.
MikeR
Ranger
Woodstock ll
When all else fails, check the service manual. It says that the 28/24 psi label is correct. That's the one I'll order.
A12
This is mine
Is that the original tire pressure label and is that a '69 383 Road Runner?
That label looks to be not for F70-14's ??
7.75-14 & 7075-15's
A12
Any chance you have the build sheet? The number of the sticker you need will be on it.
Ranger
Woodstock ll
I've had the carpets out as well as the seats. Unless the build sheet is in the headliner, I don't have it.
Anywhere in that area they were put on by people in a hurry not a machine. If you look at page one my first post the picture shows mine was lower and crooked.
Ranger
Woodstock ll
Found this tidbit in the service manual
TIRE PRESSURES
Shown on decal on body pillar, left side.
See "Tires," Group 22 for additional information.
Ranger
Woodstock ll
TIRE PRESSURES
Upon closer investigation, I see that is exactly what you guys where posting. For some reason I though you where posting pictures of the trailing edge of the door. bonk.gif
