69roadrunnin
hey guys ive been redoing a 69 road runner from ground up and im putting together the rear end and i was wondering if anyone knew the torque specs on the ring and pinion gear? i have found that on the ring is 55ft lbs and the caps are 90ft lbs i think this seems kinda high so i just wanted to double check? any info would be greatly appreciated thanks.
