mac
What ?
if i go with a stock looking voltage reg with the upated electronic guts, can i still use my dual field alternator? or do i need to use a single field?
I put the VR706 guts in my old case, then just grounded one of the field connections on the alt.mac said:if i go with a stock looking voltage reg with the upated electronic guts, can i still use my dual field alternator? or do i need to use a single field?
Well thank you Bob. BTW, when are you moving yours up 1/4" ? :acme:69hemibeep said:See, Jim known more than just decals
OUCHJim S. said:Well thank you Bob. BTW, when are you moving yours up 1/4" ? :acme:69hemibeep said:See, Jim known more than just decals
a6t9vette said:its my understanding that if your using one of the newer "electronic regulators" with a dual field atlternator that you dont have to worry about the grounding the addtional connector, assuming you have electronic ignition (i.e. no points).
I was under the impression the only time you need to ground that field connector on the regulator is if your using '69 and earlier single field "points" type regulator?
zupanj said:I like to revive this thread if I may. To begin I had my Runner on the highway twice this week and the amp gauge was reading a significant charge the whole time. Each trip was about 20 miles. The gauge was also jumping like the turn signal was on. I suspect this means that I have a bad voltage regulator but I am not sure. I always took this kind of stuff to an electrical shop in the past since thetime I went through every possible electrical part using self-diagnosis as a high school kid. I found it was much cheaper to pay someone to use their instruments to find the problem. As a result I am a little unsure of myself with some electrical issues. I don't know what kind of regulator or alternator I have for that matter. So my questions are, is the problem the regulator and if so what is the best option for replacement?
By the way, the car runs absolutely great! I have 3:23 gears in it and that works out really well for street driving. That hemi puts out enough torque to turn a house so even with the high gears, it accelerates like a banshee.
Thanks
Jack
zupanj said:John,
Thanks for that. I was looking for your post but didn't go back far enough. I guess I wasn't clear in what I was trying to describe. I didn't have my turn signal indicator on when the amp gauge was jumping but that was the way the gauge was behaving. Also I was almost on full charge all the way up the road at highway speed. The gauge needle wasn't quite so far over on the street. By the way the voltage regulator in your post looks like the one that is on my car but I think my alternator is the "old" style. I have two leads coming from the alternator, a green wire that looks to be about 16 ga and then a pair of wires coming from the other terminal. They are violet and black(?) and look to be bigger, maybe 12 ga. Does this make sense?
I guess my last post didn't make it. If it is still a points car then try the VR706 voltage reg. replacement. You can make it look stock like Big John did and make sure it has a good ground connection to the firewall. This reg uses a single field connection to the alt. They can be found at auto zone or similar for about $20. I'm assuming this problem just started. If that doesn't fix it, then it can be too many other things to just start guessing. (bad or corroded connections including the bulkhead, flakey alt., loose belt, bad battery, etc.) A cheap digital volt/amp meter is nice to have when troubleshooting charging problems. All that said, it doesn't sound like you have the old style single wire or (isolated field) alt. How many "field" connections are there to the alt.? and are you using points?
O.K. forget the VR706 replacement then. That is a electronic replacement for the point style reg. Wait for one of the "pointless" guys to chime in. Can't believe I just said that...zupanj said:I am using an electronic distributor with the Mopar digital ignition.
Jim S. said:O.K. forget the VR706 replacement then. That is a electronic replacement for the point style reg. Wait for one of the "pointless" guys to chime in. Can't believe I just said that...zupanj said:I am using an electronic distributor with the Mopar digital ignition.
If you are talking about the little VR706, you can get them all over. Auto Zone, O'reilly, even Rockauto.com has them for $10...moparstuart said:does anyone know if where i can get one of these solid state type v- regs , the mopar blue one is just too hot for my car and i dont wanna go back to the old big thick one????????????????????????
cool thanks my auto zone and advanced didnt have them ? I'll try napa and oriellys nextJim S. said:If you are talking about the little VR706, you can get them all over. Auto Zone, O'reilly, even Rockauto.com has them for $10...moparstuart said:does anyone know if where i can get one of these solid state type v- regs , the mopar blue one is just too hot for my car and i dont wanna go back to the old big thick one????????????????????????
zupanj said:Is the VR706 a constant output regulator? What I have now is the little silver regulator like the one in Stuart's photo. I have the Mopar orange box and Mopar pointless distributor on the car now. However I just got an MSD box and coil that I was going to install next week. Would that affect what type of voltage regulator I would use?
Stuart, what do you mean when you say the blue regulator is a little too hot. Does it put out a higher voltage?
