moparstuart
zupanj said:Is the VR706 a constant output regulator? What I have now is the little silver regulator like the one in Stuart's photo.
moparstuart said:this is one a friend gave me that is old and used to take to auto zone but they couldnt find me one
Notice it looks like the stock one only not as tall and thick
Autozone had it in stock when I needed oneBig John said:zupanj said:Is the VR706 a constant output regulator? What I have now is the little silver regulator like the one in Stuart's photo.
Yes, it is. The VR706 is an electronic regulator. It provides a constant output voltage rather then the off and on voltage of the points type ignition. If you have the small regulator like Stuart's, you already have an electronic regulator.
I bought mine online from Autozone because the local store would have to order it anyway. Go to the autozone web site and order there.
ArcDevilz said:John will the VR706 work with a Pertronix ignitor? I should have just bought the Mopar distributor and electronic ignition kit instead. I recently put the Pertronix in and last night while out for a drive the headlights where super dim. Charging system took a crap. Not sure if it's the voltage regulator or the alternator. I will be checking in a few hours. Just wondering though if I should switch from the old voltage regulator to the VR706 ....
moparstuart said:anyone else have problems with the blue one from mopar , ???? not to mention its really ugly and non stock looking ??????
I see alot of them on the street so i would guess i'm not the only that has this problem , mopar just sold it to me as a great upgrade , no warnings of race only .. I have now read alot about it yes being race only .Big John said:moparstuart said:anyone else have problems with the blue one from mopar , ???? not to mention its really ugly and non stock looking ??????
I remember reading that the blue regulator was a race only piece. I'll bet it doesn't dissipate heat well since its components are potted.
Big John said:Next is that you "need" to have more charging amperage. Think about it. Your old Mopar doesn't have al the current drawing electronics that a late model does. It doesn't have the current sucking rear window heater for one. Does it have A/C? Probably not. Big stereo amp driving big thumping subs? Nope.
So... all you are left with is a charging system that needs to do what it is designed to. Maintain the charge in the battery. Anything more then you need is simply harder for the belts to drive (read horsepower drain) and does nothing to help you... In fact it may be too much for your existing wiring! More is not better.
That's a normal condition on these things, don't hurt yourself looking for it, unless you have a high amp Alt on it. Mine tested at 56 amps 13.6 volts and still does that and it originally had 37amps from the factory :cheers:ArcDevilz said:So I was puzzled as to why the charging system on my car was not working. I decided to take another stab at it. I took the voltage regulator apart and noticed it was the same exact solid state one on Ebay. I started to check the wires and found that the green wire from the voltage regulator to the alternator was not passing a continuity test. I took it apart cleaned and crimped the wire and the car fired right up with the headlights brighter than ever. There still seems to be an issue with the voltage slightly fluctuating when I hit the flashers. I also noticed that the voltage at the coming out of the alternator is not matching the battery terminal. I guess I have some more gremlins to hunt in the morning.
I agree your car sounds normal69hemibeep said:That's a normal condition on these things, don't hurt yourself looking for it, unless you have a high amp Alt on it. Mine tested at 56 amps 13.6 volts and still does that and it originally had 37amps from the factory :cheers:ArcDevilz said:So I was puzzled as to why the charging system on my car was not working. I decided to take another stab at it. I took the voltage regulator apart and noticed it was the same exact solid state one on Ebay. I started to check the wires and found that the green wire from the voltage regulator to the alternator was not passing a continuity test. I took it apart cleaned and crimped the wire and the car fired right up with the headlights brighter than ever. There still seems to be an issue with the voltage slightly fluctuating when I hit the flashers. I also noticed that the voltage at the coming out of the alternator is not matching the battery terminal. I guess I have some more gremlins to hunt in the morning.
ArcDevilz said:Found this on Fleabay. Just wondering if anyone has experience with it. It seems to be an OEM replica with solid state internals. it's 25.00 with free shipping. the one at Autozone list for 26.99
Oh by the way the alternator is not charging . It read 8.6 volts. Time for a rebuild. :rimshot:
