dobie
Here we go again....The car started up fine tonight. After warming it up for a few I jump in and notice my fuel gauge is all the way to the left. Hmm...Then I notice my amp needle isn't moving. So I shut it off and everything goes dead. Turn the key and nothing. Off goes the hood and I wiggle the bulkhead wires. I get back in, turn the key, and she starts right up. Immediately though the fuel gauge goes back to "E", so I know once I shut it off it won't restart. During the time its running I have power to everything but the amp and fuel gauges. Shut it off, then nothing.
Last year I had the same issue so it went to a shop. As you look at the bulkhead connectors, the group in the middle, bottom left wire....should be a large red wire....that wire was soldered and connected inside the firewall. I can barely pull it out and get to the rest of the male terminals. So, with a small blade screwdriver I tried to get some dielectric grease in there. Hooked it back up and she fired right up. Only thing is I kept power to everything. Even took it out for a cruise, shutting it off several times.
Any idea whats going on? Sure seems like a bad connection somewhere, and its gotta be in that middle group of wires....but which one? I just packed grease in the wires in May after the last time....Is this something I should have to do every other month or so? Something can't be quite right here....
