MsBeep
Hey guys, I need help figuring out why my reverse lights don't come on when I put the transmission into reverse. The single terminal at the starter relay is connected to a single pin (threaded stud) neutral safety switch located in the A727 transmission housing. Everything worked with the old starter relay (2444442) for an A/T, and I do not have any other wiring for the reverse lights in the bulkhead. I installed a new starter relay, new voltage regulator, new battery charge wire (as per my last thread) and now: no
reverse lights. I suspect the old N.S.S. may have packed it in, but don't know how to test it. Anyone able to help??
I have a 1968 steering column-complete with the 1968 reverse lamp switch, in my 1969 Bird! I never knew until today.
