Just wanted to put it out there that this weekend I weighed the following:
1969 727 Transmission w/stock transmission pan (no converter, no transmission fluid, etc.) - 126 lbs
1967 A-833 Transmission 18 Spline (no bellhousing, no clutch, no linkage, no rods, etc.) - 113 lbs
I imagine that once the following ancillary items are taken into consideration for each type of transmission, that they would more or less weight the same?:
727 - Torque converter ( 15 lbs) + 9 quarts of transmission fluid ( 16 lbs ) + transmission lines (1 lb ) + transmission cooler (1 lb) = +/- 33 lbs
A-833 - Bellhousing ( 25 lbs?? - this is a guess) + clutch ( 10 lbs - this is a guess also) + 4-speed linkage ( 5 lbs - also a guess) = +/- 40 lbs
Total weight 727 = 126 + 33 = 159 lbs
Total weight A-833 = 113 + 40 = 153 lbs
I was under the impression that manual transmissions were 50 or more pounds lighter than their counter parts? Was that an old wives tale or what? If anyone has better numbers for the A-833 Bellhousing, clutch, and linkage please let me know. The above is just some food for thought.
I lift and balance the tail shaft with my knees and I use guide bolts in the two lower holes with the heads cut off. The hard part is getting under the tranny
