That's right no pedal after attempting to bleed the brakes. This RR came with drums all around. I bought it knowing it had brake issues.
Bench bleed and installed a reman MC no issues. Installed on the car earlier today and commenced the std bleeding regimen Rt. rear...Lt. rear...Rt. front...Lt. front. Nothing fancy mason jar half full of clean new Dot 3 brake fluid with one end of vinyl hose attached to bleeder screw and other immersed below fluid level. With wife in control central pumping pedal and I was under the car...reddish brown colored fluid leaving each bleeder screw. Never got good results from the rear drums...in other words while stroking the pedal I didn't get positive flow out through the hose. Note...I attempted to kept the MC fluid level UP....but at times I failed to stop the pedal action in time.
I was able to get positive fluid flow through the fronts...but not in the rears. Still NO PEDAL!:huh:
