Has any one put their badges on with a two sided tape instead of using the speed nuts and drilling holes. If so do you remember what you used. Don't want to drill holes in new metal.
Hello Droptop thank you for the info. Did you use the foam double sided tape. A friend of mine is redoing a cutlass and got some 3M tape but it was clear and not very thick. Also not to wide. I told him he got the wrong tape. Well going to order some today. Have a good one.3M double sided tape.
Hey Russ I drilled mine and used the black silicone from parts house
Are we done yet?
