the powermaster is the one I have
One of the greatest things about that starter is it fits everything in the sixties/seventies era with only two exceptions... Hemi 4 speed and some slant six taxis.it needs a world is flat good ol Chrysler gear reduction starter![]()
The 225 /6 with an 11" clutch used the direct drive starter. I guess it's part of the HD clutch/taxi package. I've never seen one and don't know what years, but if you look in your '69 FSM, you'll see the reference to it.Big what would be different about the taxis?
Well, it NEVER ends...……….that's what keeps me young...……….LOL
I replaced the ignition switch. Next thing to go was the starter. All I get is a loud CLICK.
So, I purchased a RECONDITIONED mini high torque starter. The parts guy could not tell me who the manufacturer is...…….running the numbers, it appears to be the same one Autozone sells, "Duralast Gold".
NOW, I don't get the CLICK but I do get a strong SPIN and still the motor does NOT turn over and I don't believe it is engaging the flex plate at all.
I replaced the stock starter and used the SHIM that the starter had. I suspect that this is my problem. I don't think the mini starter should have a shim at all.
I will have my mechanic's helper work the ignition while I take a close look at the starter.
Any suggestions highly appreciated...………..THANK YOU in advance.
LG,
Mike
