woodwiz
Getting a nice little oil spot on the floor. I’m not rock solid on it being a rear main seal, but if it is, is it a big deal to fix and cost??
From top to bottom here is what you are seeing:it seems the oil pan gasket or gaskets as it appears are in layers. Is that normal?
Not sure if the rear main is the culprit yet. Some say as long as you are in there,change it. Looking soon!
This pan is wet even in the front,just thinking it has'nt been serviced in awhile,i saw a little trace of some blue RTV along the right side,pushed out.
