Dennis Putnam
1. Is the hub on the end of the axles removable and if so how? Some of the splines that hold the wheel studs are stripped out. Am I stuck buying new axles?
2. How is the pinion gear and shaft removed from the posi differential? It appears it needs to be pressed out but I don't want to apply pressure without knowing for sure.
TIA.
TIA.
![IMG_20220819_144338120[1].jpg IMG_20220819_144338120[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/35/35954-e9de29a85fef02db2aa09368f7ff79ee.jpg?hash=6d4pqF_vAt)
