Thank you! Thank you!! Thank you!!!
Did you mean using lead in the repair?
No good reason to go back with lead. And getting it out with a MAPP torch is no problem.
Weld the new metal in.
In any event, I suggest cleaning it out as much as possible then use Fusor 2098 Crash Durable adhesive instead to fill the hole.
3M makes "impact resistant adhesive" too, but I prefer Fusor.
It's good for cowl replacements, etc. And there isn't the associated later rusting as with plug welding upside down.
Clamps are in investment.
Many thanks!You are concerned about doing the quarter/roof seam? There is lead-free solder you can use but I have never used it. My method was to plug weld the seam then weld a strip of metal over it to build up and reinforce the area so there is less to fill. I then start with ALL-Metal or you can use a fiberglass reinforced filler like Mar-Glass then last coats are with regular body filler.
Yes, keep as much of the original trunk gutter with the number stamp as you can, splice in just what you need to.One thing: I found the original stamping on the driver's side (left) upper trunk gutter. I want to save as much of that trunk gutter as possible and fortunately, that section of metal is relatively intact. Does it make sense to splice in the old section in to the new metal with the intent of keeping the original numbers on the car?
Will do!Yes, keep as much of the original trunk gutter with the number stamp as you can, splice in just what you need to.
Outstanding!!!440 will bolt right onto the 383 k-member as they are basically the same with very minor differences from `66-72.
https://www.engine-swaps.com/pages/tech-info
Thank you for the guidance!!Repair vs replace is a judgement call, if it` not too big of an area and the majority of it is solid then I might repair if any large protion needs to be replaced and/or the rest is a bit thin due to rust I would just replace it as it is a structural part of the unibody. As for a frame jig again it depends on how badly the rockers.rails etc. are and how much you are going to replace at once? You can do it in stages - replace the crossmember and floor now, then attack the next area but if you are going to cut it all apart now and have it blasted I would build or buy some type of jig to keep everything where it needs to be. I rebuilt a cab ot a truck I had and just set it up on 4 x 4s and braced it - worked out fine.
Feel free to reach out to Clayton if you need parts (314)-578-7866. I believe he ships all over. Moreover, if he doesn't have what you're looking for in the yard, he'll keep an eye out for you. He gets parts in all the time.Those are great prices, I wish we stil had salvage yards with old cars in my area but sadly they are almost all gone.
I hear you on this! The only reason I had mine on a rotisserie is because I got it for FREE off Craigs List years ago, I had to modify to fit so I have a few bucks in steel and welding supplies but just sold it for $500 as I`m done with it.Thank you for the guidance!!
The goal is to focus on allocating as many resources as possible to the roadrunner and avoid diverting cash/resources on infrastructure (e.g. 4-post lift, nice-to-have tools, frame jig) as much as possible.
