Seems like you're having all kinds of little problems Stuie! Great fix.!!!!!
this was a road bump compared to the convertible problem , the motor is back out of it and on the floor againRoadcuda said:Seems like you're having all kinds of little problems Stuie! Great fix.!!!!!
moparstuart said::jester: my spare un cut air cleaner
now you tell me dadBasketcase said:moparstuart said::jester: my spare un cut air cleaner
and here I sit without one....you Reds are just COLD.......
when we rebuilt the 440 that was in Freebird, there is a broken exhaust manifold stud in the one head. The machinest tried a diamond bit to get it out. It's still in there.
69hemibeep said:Sounds like you had a grade 8 bolt in there, I was told by a guy years ago not to go that hard a bolt in that same alternator location because they tend to be brittle and don't flex under side load and vibration. Maybe he was onto something![]()
if its bad it will happen to me , man is its raining and pouring on me right now .ACME A12 said:69hemibeep said:Sounds like you had a grade 8 bolt in there, I was told by a guy years ago not to go that hard a bolt in that same alternator location because they tend to be brittle and don't flex under side load and vibration. Maybe he was onto something![]()
Interesting...
I went through this same thing with one of the heads on Tam's Swinger a few years ago...it was very frustrating...
Another thing I found grade 8 bolts fail on is leaf spring perch to bushing. Now I twist the crap out of the suspension of my jeep and I found grade 5 bolts would groove against the perch, so I went to grade 8 and started snapping them in less than half the life of a grade 5. :cents:ACME A12 said:69hemibeep said:Sounds like you had a grade 8 bolt in there, I was told by a guy years ago not to go that hard a bolt in that same alternator location because they tend to be brittle and don't flex under side load and vibration. Maybe he was onto something![]()
Interesting...
Another thing I found grade 8 bolts fail on is leaf spring perch to bushing. Now I twist the crap out of the suspension of my jeep and I found grade 5 bolts would groove against the perch, so I went to grade 8 and started snapping them in less than half the life of a grade 5. :cents:[/quote]69hemibeep said:[
Interesting...
moparchris said:I used to be the go to man in my area for extracting bolts. The trick I use is to weld a new head of another bolt to the existing broken bolt. This does 3 things, one it makes the stuck bolt soft, two it tends to free up the threads, and lastly it gives you something to put a tool onto. Just bfore I weld it I try to drill it at VERY low speed. Once the hole goes through and through it allows the bolt to shrink and it unlocks the threads. There hasn't been a bolt I can't remove. Yet. :acme: :lmao:
Big John said:moparchris said:I used to be the go to man in my area for extracting bolts. The trick I use is to weld a new head of another bolt to the existing broken bolt. This does 3 things, one it makes the stuck bolt soft, two it tends to free up the threads, and lastly it gives you something to put a tool onto. Just bfore I weld it I try to drill it at VERY low speed. Once the hole goes through and through it allows the bolt to shrink and it unlocks the threads. There hasn't been a bolt I can't remove. Yet. :acme: :lmao:
Back in my toolmaker days I worked at a place where I was the go to guy for removing broken screws and taps. Real small screws though... 2-56 and 4-40 stainless steel screws in aluminum. I even had a special tool I ground for removing the small flathead screws intact after they had a coat of epoxy over the top.
But for the bigger bolts... Your best friend is heat! Heat 'em up, let it cool and drill in the center with a reverse ground drill. If you got lucky, the drill would start to back the screw out.
But speaking of stuck bolts, my favorite penetrating oil is PB Blaster, but I've read that the best stuff is a 50/50 mix of ATF and acetone. Anyone ever try that?
come on out mr expert i'm ready for you to fix it . :cheers:moparchris said:Big John said:moparchris said:I used to be the go to man in my area for extracting bolts. The trick I use is to weld a new head of another bolt to the existing broken bolt. This does 3 things, one it makes the stuck bolt soft, two it tends to free up the threads, and lastly it gives you something to put a tool onto. Just bfore I weld it I try to drill it at VERY low speed. Once the hole goes through and through it allows the bolt to shrink and it unlocks the threads. There hasn't been a bolt I can't remove. Yet. :acme: :lmao:
I have never tried PB, I use liquid wrench. Works pretty good and after seeing the chart above I now know why. I will have to try the 50/50 mix, I didn't know about that one. Left handed drill bits do kick butt, I have a few left but most of them broke over the years. 2-56 screws?! I dont know if I would even be able to see 'em!
