droptop said:
What size are the brakes, and is there a sway bar on the front? These are 2 common items that are over looked when cloning a car.
Yes there is a sway bar and I'm not sure about the exact size of the brakes as I didn't look. I am going to pick it up with a trailer this weekend. The only oddity that I can find is the V1W code for a white vinyl top. When the guy I bought it from bought it back in the early 80's, the man he purchased it from had re-painted it once...sometime in the late 70s or around 1980. Now, if it truly had a vinyl top, then it was removed and painted over. Thats the only thing I could find. At the time I didn't look to see if someone had spot welded the holes where the chrome would have attached between the back glass chrome and the roof drip rail chrome.
Everything else seems to match up and the man I bought it from definitely didn't do any kind of swap in recent years because the thing has about 25 years of filth and rats nests in the dash. It has three decades worth of grime on it. If someone did do a clone prior to circa 1984ish, then they went through some painstaking processes to get it right. But wouldn't it have been easier to just buy a Roadrunner at that point in time? Those cars would have only been roughly a decade old at that time and I imagine you could find them fairly easy? Plus the fact that the sequence number being off by two would be near impossible to find. So at this point, I'm not sure what the deal is. I will post a few pics once I pick it up. Regardless it will be fun to drive once I clean it up and do some cosmetics.
Here's a few of the options that the fender tag lists:
B7
Paint Code: Medium Blue Metallic
M2B
Trim Grade/Style/Color
M = Medium
2 = Vinyl Bench
B = Light Blue
B7 Upper Door Frame: Medium Blue Metallic
428 Date Built: 4 / 28 / 1969
G33 Left Hand Outside Mirror - Manual / Chrome
H51 Single Air /w Heater
L31 Hood / Fender Mount Turn Signal
M21 Roof Drip Rail Moldings
R11 Music Master Radio AM
B7 Medium Blue Metallic
V1W Full Vinyl Top - White
26 26 in. Radiator
A01 Light Package
