shar.darwish
- Joined
- Nov 15, 2015
- Messages
- 9
- Reaction score
- 0
Can anyone tell be what size oil pan would be stock for 383. While looking on the net I'm seeing different capacity sizes.
Why? What difference does the amount of oil sitting in the sump make? :huh:If you are not doing a nut & bolt resto, then why limit yourself to only 5 quarts of oil? Use the late Hemi pan. 6 + 1 capacity. Your engine will thank you.
high rpms will suck it dry. Even highway driving and being a low on oil can do it. One big culprit is high volume oil pumps which are not needed on mild big blocks.
