Is that what you do after yours sits for the winter...?Get oil pressure then prime it if needed. Also if it is a 4 speed start in neutral so the pressure plate doesn't put pressure on the engine thrust bearing.
Don't push the clutch in.I t starts only after a few turns and the oil light goes out. and it is a 4-SPEED I also push in on the clutch
Smart A$$Is that what you do after yours sits for the winter...?
Thank You !! Lesson LearnedI mentioned above the thrust bearing on the crankshaft that handles end play is dry also. Even the newer cars that you have to push the clutch in to start experience premature thrust bearing wear
