tranny fix time
just got the tranny out today and called the guy to rebuild it locally....hes on vacation till monday..WTF....what a job getting it out/also changing gears.....going from 430"S to 373"S.....should be better on the street and when i hit overdrive.....oh yeah
abodybill
Senior Citizen Member
MI. Farm
Goerge,
Good all around gear choice with the 373 :thumbsup:
Got them in two of my cars and the Runner is one of them.
Thinking about going from the 410's in the street/strip car to 373's alittle easier on the car when on the streets.
George, you're still coming out to Carlisle, right?.....yes without my car
That small change in rear cogs won't bother that beast......it will be more of a driver and wont bother the beast....lol
dropping off the tranny tomorrow......ring and pinion showed up friday......while the trannys getting rebuilt i can fix the rear main :D
dutchrunner
The Netherlands
Speaking of rearmain seal.
Hughes Engine got a one piece rear main seal. Well with one piece they mean only 1 gap.
Maybe an idea.
Good luck with the overhaul of th CRT-4.
Do they have these special clutchplates in that shop.
John puts some special stuff in his trannies.
Good luck, George. :cheers:
What is going on with everyone having rear main seal issues...??? :huh:
i ve had this leak since new.......i am looking into a vacuum pump which should help the problem
I can't wait to fire the 440 up and watch the puddle form under it, I think a rubber seal against a knurled crank might be the problem.
I have never had the problems these guys are talking about. All my big blocks have been sealed up tight.
dutchrunner
The Netherlands
I have had 5 seals replaced under warranty.
The stay closed if rpm<3500.
Above it starts getting messy.
Just rerouted my PCV and more "suction" and now is 90% less.
But still.
Anyway : A MoPar does not leak . It marks his territory. :groucho:
But still.
Or its out of oil :basketcase:
thats funny......shits and gets....oil then rubber :groucho:
just called up PTC and am sending them back my convertor to give it less stall....its about 3800.....looking for around 2500-3000 stall since i am going with 373"s.....i gave him the convertor numbers and it turns out i spent a grand on this one......so shipping back and forth 50 bucks and 150 to tighten her up is better then spending another grand on another convertor :groucho:
