Wannarunners Runner
If those are steel freeze plugs you might want to change them out to brass.
wannarunner
Yes, I do have a new pipe screw/plug and brass freeze plug kit for both the heads and block. I am kinda piece mealing the installation, lol.
John69RR
Houston, Texas
wannarunner said:
Anybody good with CSI'ing Trannies? The pad on the passenger side has (as far as I can tell) the numbers 30102570. there is the number 34104 on the drivers side. On the bell housing there is the numbers 433-8, also on the bell housing is the letters/numbers +33-8 with an X above it. There are 5 of the 12 boxes filled with the dots.
PICS
In Galens white book, automatics are stamped on the drivers side pan rail. The numbers consist of Assembly plant, Part Number, 10,000 day calander date and a build sequence number. He also states that in 69 some engines & transmissions were stamped with the 13 digit VIN on the LH top front of the transmission. Normally though only the 8 digit numiber is found. THe 34104 number does not show up in the book. 34106** or 34107** identify it as a 1970 transmission. 1969 transmission part numbers start with 28920**.
wannarunner
John69RR said:
PICS
Thanks! :thumbsup:
wannarunner
Coat of paint.
This is the area I did alot of grinding on.
Does anyone recognize these innards as stock?
Barracuda update.
wannarunner said:
Coat of paint.
Barracuda update.
By golly it is a barracuda :jester:
