One of those Sunday drivers. Or was on the cell phone.
No-haven't checked that. I'll have to look into it. Thanks for the idea.So have you checked the power booster to see if it is good or not. Or do you have a vacuum leak. When my power booster went out the pedal would go to the floor board. Just a thought Of other thing's that could be wrong. Russ.
My car is supposed to have the "Midland" brake booster and there are are rebuild kits available for it, but they are very expensive - about $300 with shipping. I think if the problem does turn out to be the booster then I'm going to see what it takes to convert the car to manual brakes. I don't like power brakes anyway.Taguy16. I seems like you are doing a good job of finding out problem's and fixing them. I have replaced the diaphragm in several power booster's before. It is tricky but take your time and it will go well. I don't know if your model car's power booster has a rebuild kit for it or not. Russ.
Yes, the rotors are stock for the car and the calipers are installed correctly with the bleeders up as they have always been. I went ahead and got new rotors and installed them, overhauled the calipers, and bled the front brakes and now I have front brakes, but the pedal still has to be pushed all the way to the floor to activate them, which is only about 6" since the brake pedal sits so low on this car. I installed new drum brake hardware and overhauled the new wheels cylinders I got for the car some time ago in case they had gotten frozen from the DOT-3 brake fluid that I had in the system that I got rid of. It's amazing how much corrosion damage DOT-3 brake fluid causes in just a matter of a year or two: you don't realize this until you start taking apart braking systems that have it in them - I don't think I'll ever use it again!As the shoes/pads wear down, yes, your pedal will have more travel and your MC will show a lower level. This is why from time to time the level is checked and if low, add some and your brake pedal should come back to a normal height. When I first got my 66 Belvedere, it needed brakes but they still worked well but the rear drums were grooved beyond the maximum but being it had 10x1.5's on it, there were none available at the time even though new shoes were available. Being a machinist, I turned them myself since I knew no one else would.
My plan was to install an 8 3/4 but it was no where near ready for that. Well, the old rear drums ended up being .040 over max size and still had some grooves in them. Geez. This was about 30 years ago and was using the car to drive back and forth to work. After getting it all back together and bled out, I figured it needed a good testing and well, it passed my test. My surprised was that they didn't warp!
Anyways, had a good pedal and the travel was also very good. Just because your rotors and drums are at the end of their useful life doesn't mean you can't get a good firm pedal. There's something else going on. Are your front rotors stock for the car and are the bleeders at the top? I've seen people get the wrong calipers or get the right swapped with the left and the bleeders ended up being lower than at the very top and you can't get all the air out. Also, drum systems need a residual valve to keep a bit of light pressure on the system to keep air from getting in. It keeps about 10 psi on the system. The MC should have it in the port. If it's not there, it doesn't take long for air to find it's way in. https://www.speedwaymotors.com/Speedway-Drum-Brake-Residual-Valve-10-PSI-Purple,7502.html
