1969 Roadrunner Full Restoration
Just little slow around here lately, probably due to holidays and such. Your work looks good, keep it up. I`m still plugging away on mine.
Greetings Everyone!
I am carrying on the conversation from the introduction forum.
Technically, the restoration process has already begun. Take a peek at the attached pics.
Goals:
1. Have the car back on the road for my son's Senior Year (2031).
2. Full OEM (as much as possible) Restoration. With modern amenities.
3. Chemical Dip - to remove all rust.
4. Frame Jig - Fabricate Frame Jig to ensure any Frame and Body panels are reinstalled properly.
5. Engine Test Stand - Fabricate an engine test stand for my 440 that is currently being built at Performance Automotive in Bethalto IL.
Front clip photographed, removed, inventoried, cataloged and missing parts list generated. Tracking all model and part numbers via spreadsheet.
Front Drive's side perspective. Note: front windshield was completely shattered with no less than (2) large holes.
Front shattered windshield temporarily stored with completely intact rear glass.
Driver's side: Removed- Door, Steering column, Bench Seat, Dash and insturment panel.
Working on Clutch Support Assembly. New floor pans are on the Replacement List.
Rear Driver's side quarter panel. Chemical dipping will reveal replacement panels and imperfections to be fixed.
Yup...no trunk pan, extensions, no rear bumper and fuel tank. Trunk lid, rear extensions, and taillight Assemblies photographed, removed, documented, inventoried and carefully stored in their respective labeld boxes.
Passengers side image: no back seat included, new floor pans required and rear manual window intact and operates!
Parts Storage: Front Bench Seat, insturment cluster, front windshield, rear windows, gas pedal pad.
Parts Storage: lower grille, Driver's/Passengers doors, steering column, upper grille, Driver's/Passengers Fenders, trunk lid, front windshield trim, hood, and dash
Let me know what you think. This is my first restoration. Am I heading down the right path? And guidance and advice?
Semper Fi
Sabre_3
Looks like you're doing fine I used a rotisserie on mine and it worked well I have tons of leftover parts if you're interested PM me
Here is start and finish. Stick with it it's rewarding
Than you so very much!!!
Your car is absolutely beautiful!!! Thank you for sharing!!!!
Wouldn't happen to know where a 440 air grabber assy. May be lying around would ya?
Ok...
So very sorry for not posting in a while!
Here's my latest and greatest. My 69 roadrunner didn't come with a trunk brace.
Soo...I was able to Salvage one from Clay & Sons Mopar salvage yard this past fall.
After some clean up, the Passenger's side of the trunk brace was toasted! (Betwee the blue masking tape)
So I measured, double checked measurements, grabbed a piece of 18 gauge sheetmetal and created a patch piece rather than purchase a new one.
I carefully made a cut along my blue masking tape and welded the patch piece and Passenger's side end together.
I welded in a small reinforcement piece that will eventually be covered with the trunk pan. It should reinforcement that weak point.
This is the side that will be see from under the car. I will trim the excess once the piece is fully fabricated.
Here is the second cut I made.
I welded the patch piece in with that reinforce the weld seam
I forgot to take pictures of the finished product. More to follow.
Next steps: Road to Rotisserie.
1. Reinforce Frame? Do I need to add temporary bracing before I put on the rotisserie?
2. Remove K-member
3. Remove rear suspension and 8-3/4 rear end.
4. Mount on Rotisserie!!!
Let me know what you think!
Semper Fi,
Sabre_3
Nice work. I mounted my road runner on the rotisserie without any bracing but except for trunk floor it had a very solid unibody structure and it is a post car so I felt it wasn`t needed. I did place jack stands under the car when I did the trunk floor, quarters and passenger floor to support the middle.
Many Thanks Sir!
My goal is to have her up on the rotisserie this weekend!!!
Then I can begin reinforcing the frame and replacing rotten frame rails!
Semper Fi,
Sabre_3
Okay,
We have updates....
So, my goal is to get her on the rotisserie this weekend (03/27-30).
As a result, I have begun removing the suspension to reduce weight and stress on the chassis and rotisserie.
So, I started at the rear end:
So, I stabilized the rear differential and leaf springs.
Well...the U-bolts were being a little fussy, so I hit'm with the death wheel.
Try not to chuckle: the 8-3/4 rear differential is quite heavy, so I built a trolley out of scrap wood, mounted my Jack's and lifted the rear differential off the leaf springs, slid the trolley under, moved the Jack's in place, lowered the rear differential assembly on to the trolley and rolled the rear differential assembly out of the car.
Kinda silly, but it worked!
I then removed the leaf springs:
The rear end is now prepped for the rotisserie!
Now on to the front suspension!
Semper Fi
Sabre_3
