torredcuda
Just little slow around here lately, probably due to holidays and such. Your work looks good, keep it up. I`m still plugging away on mine.
Sounds Good!Just little slow around here lately, probably due to holidays and such. Your work looks good, keep it up. I`m still plugging away on mine.
Looks like you're doing fine I used a rotisserie on mine and it worked well I have tons of leftover parts if you're interested PM meGreetings Everyone!
I am carrying on the conversation from the introduction forum.
Technically, the restoration process has already begun. Take a peek at the attached pics.
Goals:
1. Have the car back on the road for my son's Senior Year (2031).
2. Full OEM (as much as possible) Restoration. With modern amenities.
3. Chemical Dip - to remove all rust.
4. Frame Jig - Fabricate Frame Jig to ensure any Frame and Body panels are reinstalled properly.
5. Engine Test Stand - Fabricate an engine test stand for my 440 that is currently being built at Performance Automotive in Bethalto IL.
Front clip photographed, removed, inventoried, cataloged and missing parts list generated. Tracking all model and part numbers via spreadsheet.
Front Drive's side perspective. Note: front windshield was completely shattered with no less than (2) large holes.
Front shattered windshield temporarily stored with completely intact rear glass.
Driver's side: Removed- Door, Steering column, Bench Seat, Dash and insturment panel.
Working on Clutch Support Assembly. New floor pans are on the Replacement List.
Rear Driver's side quarter panel. Chemical dipping will reveal replacement panels and imperfections to be fixed.
Yup...no trunk pan, extensions, no rear bumper and fuel tank. Trunk lid, rear extensions, and taillight Assemblies photographed, removed, documented, inventoried and carefully stored in their respective labeld boxes.
Passengers side image: no back seat included, new floor pans required and rear manual window intact and operates!
Parts Storage: Front Bench Seat, insturment cluster, front windshield, rear windows, gas pedal pad.
Parts Storage: lower grille, Driver's/Passengers doors, steering column, upper grille, Driver's/Passengers Fenders, trunk lid, front windshield trim, hood, and dash
Let me know what you think. This is my first restoration. Am I heading down the right path? And guidance and advice?
Semper Fi
Sabre_3
Than you so very much!!!Looks like you're doing fine I used a rotisserie on mine and it worked well I have tons of leftover parts if you're interested PM me
Here is start and finish. Stick with it it's rewarding
Many Thanks Sir!Nice work. I mounted my road runner on the rotisserie without any bracing but except for trunk floor it had a very solid unibody structure and it is a post car so I felt it wasn`t needed. I did place jack stands under the car when I did the trunk floor, quarters and passenger floor to support the middle.
Oh crap!If you are going to do any reinforcing do it BEFORE you mount it on the rotisserie, I`d put it on jack stands as close o where the wheels would be as possible to simulate where the weight will be when it`s back on the ground.
Thank you for for the information!!!I found rust under the factory E coating and had to strip all new metal parts down and prime them myself after treating rust. Epoxy coated over my rust treatment. Good luck with the project. I thought the project would never end and I was right. Now putting air grabber system on the car and running into a lot of work to accomplish this. So, keep the faith and move forward. Russ.
Spraying epoxy primer is not difficult but you will need some basic equipment - compressor putting out enough cfm for your gun, HVLP require more than the old siphon feed guns, HVLP have less overspray so use less material but siphon feeds work just fine and I still use my old ones sometimes; water separator and I also use an inline disposable filter right before the gun; respirator. As far as painting I would check with whoever is going to paint your car if they are OK with you doing the prep and primer as some will not want to paint over anyone elses prep work due to warrantying their work. Worst case is you epoxy it to prevent rust and they would strip it off when you bring it to them for painting.Thank you for for the information!!!
Ok...so, did you shoot the epoxy coating yourself? If so, how difficult was it?
I'm a first time'r. Would you recommend epoxy coating yourself or hire it out (take it to a professional)?
If you epoxy coated yourself: did you have a sophisticated paint gun set-up? Pneumatic air filters, filter/driers, pressure regulator etc?
Sorry for the numerous questions, but I'd really like to epoxy coated and primer the car myself. But, I'm concerned about screwing over the professional painter that would shoot the T5 Bronze Fire.
Many thanks sir!Spraying epoxy primer is not difficult but you will need some basic equipment - compressor putting out enough cfm for your gun, HVLP require more than the old siphon feed guns, HVLP have less overspray so use less material but siphon feeds work just fine and I still use my old ones sometimes; water separator and I also use an inline disposable filter right before the gun; respirator. As far as painting I would check with whoever is going to paint your car if they are OK with you doing the prep and primer as some will not want to paint over anyone elses prep work due to warrantying their work. Worst case is you epoxy it to prevent rust and they would strip it off when you bring it to them for painting.
