I was busy cleaning it!Hoosier Bird said:Either you didn't bolt anything on the car last night, or you are not following the rules........ :toetap: :toetap:
2 hours cleaning the bottom off
Plymouthfan said:Are you drop the body over the engine/trans or drop the goods in from the top?????
69hemibeep said:I was busy cleaning it!Hoosier Bird said:Either you didn't bolt anything on the car last night, or you are not following the rules........ :toetap: :toetap:![]()
ACME A12 said:I was busy cleaning it!69hemibeep said:[quote="Hoosier Bird":11w0acdt]Either you didn't bolt anything on the car last night, or you are not following the rules........ :toetap: :toetap:![]()
No overspray so I'm on my way to the fridge. I was pretty careful I bagged the whole carRoadcuda said:That looks great Bob. But, better you then me doing that after a fresh paint job. With my luck I check it 10 times to make sure there were no gaps in the masking, and there it would be when I thought I was finished! Black where it don't belong. My guess is that the fridge door stayed closed untill you were finished!
69hemibeep said:Here is one scary job, doing the blackout on the support with new paint :cheers:
John I got the info from a thread on moparts some time back they had Chrysler info according to the A12 gurus. I will double check here was one exampleBig John said:69hemibeep said:Here is one scary job, doing the blackout on the support with new paint :cheers:
I may be wrong, but shouldn't there be paint on the inner fender below the headlight? You can see that through the slot on the filler panel under the grille.
69hemibeep said:John I got the info from a thread on moparts some time back they had Chrysler info according to the A12 gurus. I will double check here was one exampleBig John said:69hemibeep said:Here is one scary job, doing the blackout on the support with new paint :cheers:
