bigmanjbmopar
- Joined
- Feb 24, 2012
- Messages
- 395
- Reaction score
- 26
Just out of curiosity while you had the pump off and the pan off did you happen to blow air through the pump holes to the pick up? Just to make sure there is flow from there if so it makes send the reverse is good. Sound alike blockage in the block / bearing passages I would pull the motor and give it a refresh why fight it? If you can't get any pressure or oil up to the rocket shaft you have blockage internally period.
Or just have a cold one.
